Control surface servo/load
Old 01-19-2002 | 12:50 AM
Default Control surface servo/load
Between the rudder and elevator which servo has the most load on it?
Old 01-19-2002 | 01:57 AM
Default surface load
You haven't provided enough information AV8or. The load on a control surface depends on several factors. How much deflection, how big is the surface, are there any aerodynamic balances,servo tabs, etc.
Old 01-19-2002 | 02:12 AM
mselby's Avatar
It would also be useful to know what plane we are talking about.
Mike
Old 01-19-2002 | 12:37 PM
Sorry - a 25% Edge 540. Both the elevator and rudder have the scale counter balance tips with weight.
I do not know what servo tabs are.
Old 01-19-2002 | 09:53 PM
Default servo load
in this case the surface with the largest area has the greatest load.
Old 01-20-2002 | 06:58 AM
My Feedback: (31)
The rudder, without any doubt... Use something like a Hitec 5945. JR8411, JR4721 or another servo with at least 100in. ozs.
Old 01-20-2002 | 12:36 PM
Cactus.'s Avatar
http://www.multiplexrc.com/calcservo.htm
give that a try
Old 01-20-2002 | 04:02 PM
Thanks to all, and thanks for the servo analysis calculator phillybaby. I am still in a quandary in my servo selection for this 25% Edge. The best servo I have right now is an Airtronics 94158 servo which has 145 in/oz of torque and .10 sec per 60 degrees rotation according to Airtronics. The rest are standard servos. My thoughts then are to put this on the rudder. For the elevator I can't decide to go twin servos like a HS-225MG or a stronger single like a HS 545/605/or 625. I will play around with this servo analysis calculator and see what it offers.
Old 01-20-2002 | 06:23 PM
Cactus.'s Avatar
when i use that servo calc i go a little OTT on speed so i WONT! get any problems, with which servo you use for which... you can land a plane if you lose rudder, you can land a plane if you lose one side of the elevator, you cant land if you loose elevator compleatly, ( ok, yes i know, its been done, i've done it too )
If your gonna have sommit that big i would use two servos for the elevator, and then you can get a bit of taileron mixing going too for more fun, better for prop hanging i beleive...
I always put my best servos on elev and air, then throttle and rudder can have the less powerful or crashed before ones..
