Jr 8411
My Feedback: (195)
IN
Jr 8411
Do these servos make a alot of noise your do I have bad ones? Thay are being used on elevator on a 40% cap setting at a idle they make more noise than I am used to. Is this normal? Thanks Jeff
MD
8411 noise
They do make a buzz/hum if they're working a little.
The noise can also tell you there's just a little binding in the system that prevents the surface from returning to exactly neutral,
Couldn't hurt to check... will save battery life too, if that's the case.
My Feedback: (15)
Bzzzzzzzzzzzzz
The buzzing indicates that there is some force working against the servo when it's on. You can make the buzzing stop by lifting a control surface so it doesn't put any pressure on the control rod. Big birds buzz like crazy, especially when there are multiple servos on the same surface and they aren't perfectly matched.
Bottom line, completely normal characterstic for a digital servo.
Jason
Jason
My Feedback: (23)
Jr 8411
Normal yes, but when they buzz they are pulling more current, the louder the buzz the more current.
The 8411s have a very small tolerance at center, just the weight of a flying surface could pull enough to make them buzz.
Anyone have suggestions on when the gears should be replaced due to increased slop?
My Feedback: (15)
slop
Mine have developed some slop after a lot of use, but not so much I need to go out and replace the whole gear train. I've found that by replacing the single nylon relief gear (about a $2 part) I cut out about half the slop.
Jason
Jason
