Can I double back the antenna wire on itself?
My Feedback: (24)
Due to the rear mounting of the Rx in this plane, my antenna options are to have 85% of the antennas wire exit the bottom of the fuse and drag along the ground and trail along in the air. Or, to route it forward to just behind the canopy, exit the top of the fuselage, and tie up at the top of the horizontal fin.
Would doing that, doubling back over itself, create problems for my reception?
TIA,
-Tom
TIA,
-Tom
My Feedback: (13)
RE: Can I double back the antenna wire on itself?
doubling back is not recommended because it may cut down your range somewhat. Usually not that much however. I'd try it on the ground and do a range test fully extended and then try it again at the same time and place, but with the antenna folded over itself.
This is the method practiced by most AMA rulebook pylon racers in the country (Q-500 and Q-40) where exposed antenna is an unacceptable drag penilty. The straw can be positioned forward or backwards.
John
http://www.darrolcady.com/Racing_Inf...ch/Antenna.htm
John
MN
Tom,
I would bet your original picture would give you a solid range check. The picture that John shows is commonly used in 180 mph planes with NO problems.
The trick with any antenna installation is to range check.
I routinely double back, but from one side of the fuse forward, loop around the tank, and then back down the opposite side of the tank and out the back. I normally only tape about 1" of the end of the antenna to the rear of the fuse. Once again, fast planes that get close to 1000' away at times. This could also be in a plane with large concentrations of carbon fiber, or near carbon fiber pushrods.
I hate to harp, but the range check will tell you if you are ok.
Good luck.
Good luck.
ORIGINAL: JohnBuckner
John
John
http://www.rc-cam.com/ant_exp.htm
Regardless its a method that works well in the application indicated by people involved all over the country as well as the method described by Daven in his post above and both methods has been tested extensively for that application by most involved.
John
John
My Feedback: (19)
NY
Any of you guys ever buy a HiTec receiver that comes with the "antenna bobbin?" It's a flat piece of plastic 1 1/2 inches long and 3/8 wide. Instructions from HiTec say to wind up to 18 inches of antenna onto the bobbin without crossing wires.
GA
There is also other things that that guy failed to mention or test, and he didnt wrap that straw correctly either. On some sections of the winding he overlapped the wire, of course its going to reduce range if its tied in knots around a straw.
Also he didnt tell you about what changes are made to the recievers DIRECTIONAL ability to recieve a signal. A wound antenna can recieve signals from 360 degrees all the way around the antenna.
Ive used straw wound antennas for a LONG time. Never once had a problem with any of them, as a matter of fact, I honesly believe I got BETTER performance out of the wound antenna's on some of my helicopters....but you do have to wind them correctly.
The windings should NEVER overlap.
The windings should have even spacing between them.
They should NOT be wound around conductive materials such as aluminum, or carbon fiber.
ORIGINAL: bdavison
This is not true on either the photo I provided of one of mine or the link provided there are no knots or overlapping with roughly equidistant spacing the entire length. You would have known this if you read the detailed description provided at the site.
My Feedback: (54)
I've got a Patriot XL with the receiver in the tail. I ran the antenna up one side of the fuse, rubber band to a cuphook in the front, and back down the other side of the fuse. Rock solid. Your mileage may vary but I'll bet you'll be good to go.
