FF 9 question
FF 9 question
Guys, a quick question for ya. I'm fitting a H9 P51, paired ailerons, two flap servos, two elevator servos, throttle, rudder, gear. Cannthis be done on an 8ch Rx? I have used the "ailevator" mix for the two elevator servos but this now seems to preclude using a spare channel for the second flap servo, yet I still have an output free ont he Rx. Am I missing a trick here or do I need to go and get a 9ch Rx. (Or did you other H9 users mod it to be able to pair the elevator servos?) NB, I cannot Y lead the elevators as I am taking outputs from OPPOSITE sides of each one, so they MUST rotate in opposite directions if I am to avoid tailerons!!
David
David
