6v regulators
My Feedback: (23)
6v regulators
I would like to know who makes a good quality 6v non-switching regulator?
I have heard that the switching regulators can cause interference, but have no real proof of this, if someone could provide me with some insight I would appreciate it.
6v regulators
Craig,
There was a discussion just over the last few days on the Scale Aerobatics list about switching regulators. There was mention regarding actually seeing the differences between a switching and non-switching regulator on a spectrum analyzer. The switching regulator shows a marked increase in noise and interference. There was no mention to the brands that were used for the test.
Going to a non-switched regulator as you suggested is a wise move. I'll try to pull some of the discussions from the archives, and see if I can't glean some names in the process.
What batteries and voltages are you planning on using? 5 cell NiCad/NiMH/Lithium, or Lith in 6v, 7.2v or 14.4v varieties.
My Feedback: (23)
6v regulators
Li-ion 7.2v.
I am curious just how much interference is generated by these switching regulators. If it is not much, then some distance between them and the RX should take care of any problems.
I would think that people are using switching regulators without problems. I just want to know some kind of data stating just how much difference in interference there is with switching and linear regulators.
6v regulators
Originally posted by woodscra
Li-ion 7.2v.
Li-ion 7.2v.
I'll see if I can't find some hard data on the differences, and what the specifics are in relation to noise, interference, etc. It might take some time though.
The consensus is that non-switched regulators are the preferred method as they are less prone to causing interference issues, but switched regulators do indeed work for most. Maybe Conservative, maybe not.
My Feedback: (7)
6v regulators
Originally posted by sfaust
Even if the distance were increased, the interference could still have a path to the receiver via the control and/or the power wires, since they all end up at the receiver together.
That's just what I have been trying to get across, If you use optical isolation, and a different battery for the receiver then that of the servos, nothing can ever get back to the receiver hence no glitches.
regulator.
i was told that most of the 6v regulators available are rated 1 or 2 amps only and that they are overload protected and they protect themselves by dropping the output voltage. volts= current x resistence. in high current manouvres, snaps etc, on a large model with lots of high current servo's working hard it HAS been known for the voltage to drop below that at which the receiver works resulting in a rekitting of the model. this was proved on the ground by applying load to the surfaces with all switched on and the receiver stopped working. when someone brings out a regulator capable of 20 amp current load i will use one. until then i'll get batteries the voltage i need.
My Feedback: (7)
Re: regulator.
I have never used a regulator and don't plan on using one anytime soon either, and I have been at this for a long time.
6v regulators
I should probably also mention, that switching regulators are rumored to have the potential of increased noise issues, but in the same breath, most people don't have these issues when using them. It may be an issue that is prevalent in only specific circumstances.
Why wear a band aid, if you can avoid the cut in the first place.
