Throttle/Brake Trigger Modification
I run powerboats and use a wheel type transmitter with throttle trigger.
In my boats I do not have reverse or brakes.
The throttle trigger with these radios is centered. Push forward for brakes, pull back for forward.
I want to use the full range of this trigger without the center detent to desensitize the throttle.
How do I modify the trigger so it stays fully forward (brake position) for the idle position and have it smoothly pull all the way back for wide open?
I am only using half of the servo travel for my throttle. I want the full range of the servo travel for this.
