Split Elevators with dual servos
My Feedback: (9)
OH
I setup my Extra 330 with dual servos in the tail for the elevator. I thought I had everything configured the same on both sides, but when I move the elevator stick quickly and watch the control surfaces. One moves slightly different than the other one. I'm worried that if I pull back quickly in flight the plane will go squirly because they aren't moveing at the same rate. Is there a way to make them track at the same rate? I'm using a JR 8103.
My Feedback: (16)
GA
The simple answer is no.
Unless you run them from the same channel, this will happen with any radio.
Some are not as bad as others but they all do it.
