servo flutter
servo flutter
I have HS4556MG servos mounted in a 28%Texac Hurricane with a JR 700 PCM receiver and a JR 9303 transmitter, power by a SR 1800ma 6 volt battery. The problem is that the servos flutter and jump around when they are powered up. I thought that it was cause by the transmitter being to close. But I see it happening in the air and it’s scary when it happens. The plane doesn’t get out of control, but it does act up enough to see. Is there anything that I can check or change to fix this issue? Thanks
RE: servo flutter
Hi
You can test you servos with a tester to see if the is a problem of the radio receiver o from the servos. In www.rc-devices.com the sold a servo tester so you can test this.
