Futaba 9C PMIX Rud->Ail problem
Hi to all,
I am using two aileron servos on ch 1 and 6.
When I am setting a PMIX to mix Rud->Ail the LINK option, which should be available to turn ON (according to the manual), is not displayed at all.
I try to do the same on another memory position without setting anything else and it works fine.
My question: What is wrong? Is there anything that I have setup which could cause a conflict to the Rud->Ail PMIX?
Please help
Please help
IL
Costas, Yes, you have another mix set somewhere which has link on which uses either rudder or aileron. This is causing the link option to be hidden.
