JR Servos Buzzing
NV
JR Servos Buzzing
I just put my new JR system with 537 servos in my WM T-34. For some reason the servos buzz part of the time in the neutral position. They all do it and I have removed the push rods from the servos to eliminate the load and they still do sometimes although less than with the rods attached. Seem to use a lot of power since when I cycle the battery it seems to have used a lot of power in only a few minutes of operation (over 500mah in 20 minutes). What is going on? What should I try? Thanks for any help.
Mike H.
Mike H.
RE: JR Servos Buzzing
My servos always buzes when they can't return to their neutral position.
When I remove the pushords tough, and if nothing is retaining the servo's arms the buzzing stops on the spot.
I didn't notice any extra discharge from the battery, and I use the same servos as you mentioned.
I can fly more than 10 times, 15min each, on the same charge.. Battery is 1100mAh
