Nomadio FULL Range 2.4Ghz aircraft radio
#226
My Feedback: (21)
KY
The rx voltage is the biggest - make sure the rx can handle it. As long as it can, the servos can be produced to handle the increased voltage. The 5955's / 5995's are robot servos that we use in RC airplanes and can handle the higher voltage.
#228
By the way I know this is bad form but the design team would is reading on the Nomadio forum now they said it just to much to keep up on 4 forums.. LAZY EEs
#229
ORIGINAL: cadconversions
So, you go 2 - A123 cells without regulators into the rx? Can't you quick charge them as well?
ORIGINAL: dick Hanson
Don't like regulators -neither do I
I am switching over to A123 cells running em direct in my models
All in all they easily beat the present LiIon technology -not quite as light as LiIon but in all other respects far better. they provide incredibly quick operation used with my DX7. Nominal voltage is 3.6 per cell.
So a 2S1P 2300mAh Rx pack would weigh about 150g with operating voltage in the range 7.2V to 5.0V but around 6.5V for most of the charge.
#230
Karlton
The 4/7 channel radio that you have coming out first, will that have heli setting or plane and car only? As I fly helis mainly but I have plane aswell.
#231
TX
ORIGINAL: kgfly
A123 cell specifications are: Nominal 3.3V (3.6V fully charged, 2.5V ~90% discharged, 2.0V 100% discharged,), 2300mAh capacity, fast charge at up to 10A (4C => 15 min), 1000 cycles @ 10C to 100%discharge, 70g/cell. See here: http://www.a123systems.com/html/products/cells.html
Just thought you might want to be aware.
#232
TX
Ok, just finding this thread but here's my thoughts.
Receivers:
1. I can't believe no one has said this, or I've overlooked it, but I'm sick and tired of being sick and tired of having to use a regulator with my receivers. Make them li-po friendly with a voltage aleart around 6.3 volts so you have time to land and recharge. I know that only the 5955's can run on 7.4v right now (not advertised but they do) but it would force the manufacture's hand as well and they'll give us some servos that will work with it. To me, that's huge!
2. The other huge thing that's never been done is to put a deans (I prefer Anderon Powerpoles) on the rx case so that the batteries can go through the connector that's rated higher than 3 amps. With today's high draw digitial servos, we need more than 3 amps! Look at the companies and the people that spend hundred of dollars on items to regulate and then to provide upwards of 3 connectors to the rx to try to hold the power required. Possibly add a second input for redundancy but for those that want that, they could buy a dual battery setup from smart-fly...
No regulators, no wimpy connectors, and that means no competitors.... The way I figure, each servo connector is fine since there's only one servo going through each connector. However, a single servo lead can't handle the loads required of all of the servos. Powerpoles or Deans can!
That's it for now, really got to get to bed. I think this list will give you a couple of things to think about
Receivers:
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
You do realize it is easy to hook up lots of high amp servos, totally bypassing the radio connectors for oomph, right?
You only have to have ground and signal from the servo hooked to the radio (for the position signal). Positive can be routed to a totally separate power source. This was pretty common before the BEC days (hence BEC - Battery Eliminator Circuit). You need to run 10 each 10 amp servos, at 12v (if you have such) go right ahead, and use whatever connectors you want. Just run a 2 wire (ground and signal) tap to the radio from each servo. Of course you want to make sure everything has a common ground...
Actually, some people recommend a separate power source for servos to help reduce glitches due to noisy servos. This is also a common recommendation when interfacing servos to microcontrollers.
Wreno
#234
Hi!
There are rumors told at RCGroups that Nomadio might be thinking about making their planned TX compatible with the XPS system, or even about licensing the whole XPS transmitting technology.
http://www.rcgroups.com/forums/showp...postcount=4358
This sounds too good to be true, but I have to ask nonetheless:
Is it true?
Cheers,
Julez
Is it true?
Cheers,
Julez
#235
Hi, Re. the 4/7 ch system. I would like to see a very compact transmitter size. Something that's easily packed for commercial air travel. Ideally, the antenna would be removable or collapsible, again for easy packing.
rivers
rivers
#236
I put a 4ch react board in a MPX Pico case no antenna exposed out of the case it works
Just as a proof of concept
#237
My Feedback: (19)
FL
Karlton,
Better start gettin jiggy wid it
. Couldn't wait any longer as the technology is available, so I bought a DX 7 to use until something better is available. Should have no problem peddling the DX 7 when the time comes .
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
#238
AK
This should get interesting in a couple of months,,Nomadio,comeing out with TX like the 14Z,,full of whistles and bells,,,but more channels,,,Xtr,comeing out with modules to fit the type of Radios people are useing now,,If i read right,,Xtr has been testing a module in a JR 10X allready,,should be interesting in the next few months,,
NdFrSpeed
NdFrSpeed
#239
We are not going to rush it to market that is for sure. But we already can talk their receivers so you can use our radios with their receivers you had to use.
#240
Karlton thats great to hear, any of the other big companies wouldn't do this to try to make more money for them selfs but you guys are looking at the bigger picture (helping the customer) which is rare these days, fair play lads.
#241
TN
ORIGINAL: Nomadio_Sales
#242
Just to be clear, are you saying you can already talk to both Spektrum and XPS-XtremeLink receivers and that your new air radios will be able to be used with AR7000, AR6100, AR6000 and the full range of XPS/XL receivers so sunk investment in those Rx will be protected ?
#243
CO
Boy am i glad i found this thread before I went out and bought a 12z. I can't wait to hear more on this thing.
I am one who does like a product to look pretty though, so any concept art of what its going to look like would be great. I do like the way the Sensor looks. Crazy, sophisticated and original. Will the A/C radio be a multiplex design (like the react), or based on it and modified?
#244
So I have this 1000.00 burning a hole in my pocket......lol. Still have it in the safe for this radio. Really excited to get one! Is there a way to get you to email me when it's released? I can pre order if nessessary too. Just let me know how you would like the funds
#245
Hi!
I just read that Futaba was licensing Nomadio technology for their 2.4GHz stuff...
Any comments on this topic? Perhaps this would allow Nomadio to work with Futaba RXes?
And what about the rumored compatibility with XPS?
Cheers,
Julez
Cheers,
Julez
#246
ORIGINAL: Julez
Hi!
Cheers,
Julez
Hi!
Cheers,
Julez
Later;
D.W.
#248
Hi!
I read it here: http://www.rcgroups.com/forums/showt...86#post7066086
Yeah, I'm not really holding my breath as Futaba Modules are just a rumor yet, so I'll stick to XPS for the beginning. But compatiblity is always nice, I think. And therefor I really HOPE that Nomadio will be able to work with XPS.
#249
MN
I wouldn't consider that rumor to be anything more than uninformed speculation. There's no source for it and there's no reason to give it any credence.
#250
ORIGINAL: Julez
Hi!
Hi!
Later;
D.W.
