Expo setting on a Hitec Eclispe 7 radio
RE: Expo setting on a Hitec Eclispe 7 radio
All Hitec computer Tx's that have Expotential: Prism 7X, Optic 6 and Eclipse 7 for softer center sticks (this is what you are looking for) are programed with negative expo also be aware with the Prism and Eclipse that the expo is avaliable on all three axis (aileron, elevator and rudder) as well as high and low rates. Expo on high and low rate as well as each axis is set up separately and each may be of a different setting.
The simple answer to your question is Hitec is programed with negative expo for what you want.
John
John
G'day Mate,
I have edited my post because I checked the Eclipse 7 manual & negitive is softer around neutral, same as Futaba & opposite to JR.
Sorry My mistake,
It is still easy to add heaps & make sure it works the right way, then reduce the amount of expo to around 15% & adjust as required.
Sorry My mistake,
