DX7 help please
OK
DX7 help please
when i went to set up a model with my DX7 i discovered that the reciever does not respond to tx commands. the leds on the reciever that normaly blink when the reciever is on only blink once when the power is first turned on. the reciever has not been bonded, the conection between the reciever units is good. any idea as to the problem?
rcpilotcd
rcpilotcd
RE: DX7 help please
Did you use the Spektrum supplied 3 wire switch harness? The Tx and Rx will not bind if you use the normal 2 wire switch harness.
ORIGINAL: rcpilotcd
rcpilotcd
rcpilotcd
IL
RE: DX7 help please
RC pilot,
Yes, the single flash then off means that you have not performed the bind operation for the specific model memory you have called up. If you insert the bind plug it will begin flashing indicating it is ready for bind. Follow the instructions. (except in line 5 it says remove the bind button and it means remove the bind plug)
Regards,
Regards,
