Throttle servo mounted on firewall is this O.K.
My Feedback: (51)
QC, CANADA
I have mounted the throttle servo on the firewall, this is a Ziroli B-25 with G-38's the reason is I wanted the simplest direct linkage from servo arm to carb with no loose travel so I can syncronize RPM's on both engines. Having said all that will there be too much vibration at this location for this setup.
Thank you
Tony.
Thank you
Tony.
CO
RE: Throttle servo mounted on firewall is this O.K.
I have mine ~4 inches from the ignition module on a DA100, using a ferrite choke on servo wire and no problems.
