Skysport 6A Flaperons
Hi guys,
I have aSkysport 6A Tx hooked up with a Seagull SpaceWalker II and have set up the silerons as flaperons. My question is this - When I adjust my flap knob, turning it anticlockwise from center makes the flaps come down, but when I turn the know clockwise past center, the flaps/ailerons turn into spoilers and point upwards.
How can I set the Tx up so it won't allow this?
Cheers, Paul.
Cheers, Paul.
RE: Skysport 6A Flaperons
the easiest way would be to simply reposition the servos. Set the flap control all the way clockwise and then line the aileron servos where they should be during normal flight. After that decrease your EPA (End point Adjustments) so when the flap control is turned counter clockwise, it won't extend too far.
