PCM Question.....
TX
PCM Question.....
I currently have a Futaba 8 Channel "Super" radio. It can be set to transmit either FM(PPM) or PCM. It's now on FM with an FM reciever. I have a question about possibly switching to PCM. If I were to buy a PCM reciever, does it use a special RX crystal or just an FM one?
Thanks........
Thanks........
RE: PCM Question.....
Hi there.
The RX crystal is the same for both what you refer to as "FM" (more precisely called PPM) and PCM.
With Futaba you just need to make sure to get a DualConversion crystal for a dualconversion RX. The receiver is normally clearly marked if it is a DualConversion or not.
-Go for a DualConversion RX!
Good luck.
RJ
Good luck.
RJ
My Feedback: (29)
TX
Hi Bear,
Remember to get the correct band of PCM receiver. Loband is 11 to 35, hiband is 36 to 60. Some newer PCM receivers have only one band from 11 to 60.
Dave
Dave
TX
ORIGINAL: davewallace
Hi Bear,
Dave
Hi Bear,
Dave
PCM is also FM. It's just encoded differently. Also, your ONLY source for a RX that will match your Futaba PCM is Futaba. The coding is proprietary and nobody (that I know of) makes a compatible aftermarket RX.
It sounds like you may have a 8UAPS. I think this is a 514 PCM. I'm attempting to verifiy by my slow connection will take a while to download.
If it is a 514 you will have a hard time finding a NEW RX since they have been out of production for some time. If you need a 512 RX look for a R127DP (7 ch) or R128DP (8 ch).
You may end up better off staying with FM.[]
I'll be back with an update.
Make sure you get a Futaba PCM receiver - you can't mix brands with PCM, every manufacturer has a different way of encoding the PCM signal.
The 8U series of transmitters is PCM1024, so it will work with any of the current Futaba receivers. It will not work with an FP-R128DP - thats an older PCM512-only receiver. You also don't need an 8-channel receiver - I've used my 8U on a ground frequency on a 3-channel receiver and it works fine, also works with 9 channel receivers.
ORIGINAL: BillS
I also have the 8UAP Futaba radio and have a mix of PCM and Futaba PPM and Hitec PPM receivers.
Bill
Bill
No, every mfg developed their own codes. I don't think there are any rules/laws stopping anyone from duplicating the coding. They just haven't that I am aware of. Might be a patent deal though.
ORIGINAL: bruce88123
Even JR makes a PPM that's compatible. It's the PCM mode that is proprietary and restricts him to Futaba if he want PCM operation.
ORIGINAL: BillS
Bill
Bill
Bill
ORIGINAL: BillS
My JR receivers have are opposite shift from Futaba.
Bill
ORIGINAL: BillS
Bill
Bill
Bill
