synthesized downside
why is it , that some receivers won't work in conjunction with a synthesised tranny module??? ( certain indoor types )the receiver in question is fine using the zap with the crystal module but not the synthesised one WHY?? surely the signal output is the same regardless of the module type used? at least GWS receivers work with synth modules. YIPPEEEEEEEE.
NY
Well considering the signal is generated different it can't be exactly the same, it might have some harmonic or distortion in a place where the receiver doesn't like it. Could be a problem with single conversion receiver?
