4* 60 Servo Extensions
I was just about to order my flight pack from tower for my 4* 60 build that is almost complete.
I have a couple of questions for the group before doing so.
1. What length and size aileron servo extensions should I use?
I'm thinking 18" extension heavy duty would be best.
2.Should I be concerned with interference with these extensions?
3.Do I need a 6.0v battery pack to compensate for the extra length in wire or will 4.8 be o.k?
Any other suggestions or information welcome.
Dbow
Dbow
OR
I used a y-connector with 12" extensions on mine. If you are useing independant channels for each aileron, regular 12" extensions should be fine.
Should be no problem with interference.
No, a regular 4.8v battery back will be fine.
As far as other suggestions go, use the search function, there are tons of threads on 4* mods etc.
