receiver battery connection?
I got an ultra stick that I want to run with the quad flap setup--however, my receivers are 7 channel, I need 7 seperate servo connections, so where to connect the battery?? Can I use a Y harness on the battery/7 connector between the 7th servo and the battery? I thought I read somewhere that this was possible, but I can't find it now. Thanks for the help, Mike.
Yep, no problem. It's the same power buss, so it doesn't matter which hole the battery is connected to. You can use a y connector with any channel, like you though.
