Plug into any open receiver slot!
What does that mean exactly?
would it work with a Y on a servo sharing a channel?
I'm talking about the Spectrum voltage protector
thanks, Vasek
thanks, Vasek
RE: Plug into any open receiver slot!
ORIGINAL: vasek
thanks, Vasek
thanks, Vasek
ORIGINAL: jerdavis
yes
yes
It's all right here:
Plug into any OPEN receiver slot!
Rafael
Could give a good technical reason why the capacitor would not do the job if there was no open slot and you used a "Y" harness to connect it either to the ESC/BEC throttle connector or the battery connector[:-]
Pete
Pete
sorry Pete I didn't get your answer.
a battery can be connected via a Y harness into any "open" channel with a servo, since the battery has 2 "power" leads only therefore NOT affecting the signal wire for the servo function thus plugging into the "power circuit" only.
why wouldn't a capacitor work also like that?
It will work just as well Y'd in as it will with a dedicated port. The RX busses are all tied together internally and don't "SEE" a difference electronically.
ORIGINAL: pilotpete2
Pete
Pete
Anyway, why not ask the same question on the Spektrum Support Forum as I suggested? Anybody care to do that? Or are we going to just make assumptions when the horse's mouth is just a click away?
Rafael
ORIGINAL: vasek
thanks, Vasek
thanks, Vasek
If you are thinking that this is for use on airborne Rx's then read this quote:
RE: Low voltage capacitor - 10/30/2007 9:35:34 AM
No New Messages
dsnyder
Moderator
Certified
Status: offline It would not do anything in an airplane. It is designed for 1/12 scale cars that use 4 cell batteries to power them, and hence the BEC output of the ESC is low. They will not do anything or help anything in an aircraft.
_____________________________
Danny Snyder
Horizon Hobby / Team JR
(in reply to presso)
[View this members gallery] [Search users posts] [View My Models] Report | Post #: 2
ORIGINAL: Rafael23cc
No, I can't. I know what you guys say, but right there on the description of the capacitor, and most likely on it's literature it says OPEN slot on the receiver.
Rafael
Pete
Pete
Rafael
