DX7 power on Problem with msg DMC
hi
i had a problem with my DX7, no power at all, i found out the problem with the fuse inside,
i replaced the fuse with new one, and it start working again . BUT
when i switch on it works fine,
when i switch off it keeps on with message appear beside model name DMC.
now i cant go to options menu by pressing Down+select while turning on.
because it is not off.
please advice
please advice
RE: DX7 power on Problem with msg DMC
G'day Mate,
You have probably shorted out the jack socket, in the back of the TX, that is used for trainer leads.
It is behaving like it has a trainer lead plugged in, I'm sure it does not, but if you jammed a wire when you changed the fuse, it could be shorted, take the battery out & then remove the back of the TX, & make sure nothing is jammed in the jack socket.
