Spektrum/JR Flight Log - head scratcher
Just received my new JR X9303 2.4 system and also purchased the Flight Log. I bench test my all of my radio equipment because I find that it really helps my persoanl learning curve and that is what I am doing at the moment with the Flight Log. My understanding of the instructions indicate that you have to leave the power on after a flight and plug the Flight Log into the Batt/Data port of the RX which means that you hae to pull the plane apart each time to get the data or have a servo extension hanging outside the airplane somewhere. This seems too outlandish so I figure I must be reading the instructions incorrectly. If I am reading them correctly I would guess someone has developed a better way and if so please share it with us. Thanks [sm=spinnyeyes.gif]
Howard
Howard
My Feedback: (41)
RE: Spektrum/JR Flight Log - head scratcher
Or if you have the battery power leads from your switch put into the Batt/Bind and Batt/Data ports and three wires from the switch to the rx, you can just pull the readings from your charge port on the switch for the data side. Just shut off that switch and leave the other one on. This of course assumes you have dual switches/inputs for power to the rx.
Considering all the battery options available and what you may want to try in the future, I think Josey's method is probably the best. Just hook up a Y lead into that port and run it to the charge jack. You'll need a double male or female end lead for it to work depending on your exact wiring setup tho...[8D]
My Feedback: (198)
After doing the Ernst jack thing, learning that I had to have a male-male wire to make that work right, I went to the switch configuration Zeeb mentioned, and that works well. I just had to label which switch was the "data", then, of course, remember to NOT shut off the OTHER switch when landing.
The gender issue on the Data Logger is a problem, too....it comes with a Male (for plugging into the RX), and doing the switch or the Ernst jack system, it needs to be "Female", so I just spliced on a female permanently to the Logger.
Sadly, I also have found that after verifying a configuration a few times, and finding little to NO difference in the logged data, the whole process is moot....had I anticipated how little I would actually CHECK the thing in practice (after confirming initial setup, or after a configuration change), I would have just hung an extension out the hatch or wing root and been done with it. Live and learn. [)]
Josey, Zeeb and Bob,
I got it - I just thought it was such a bad design (not the Flight Log but, how it is interfaced) that I surely had misread the instructions. I'll give Spektrum an A for effort and a D (at best) for implementation - of course a good counter argument would be to use a competing product but, there isn't one. I guess that puts Spekrum up toward the front. This afternoon I will either finish an engine swap on my twin or work on an 'in place' harness for the Flight Log.
Yee gads Spektrum, I can't believe this product made it through a design review.
Howard
Howard
Howard,
I use this,
http://www.horizonhobby.com/Products...ProdID=JRPA025
already has the Male-male plug in it....and has the proper polarity on the connector that mounts into the side of the model.
It is designed as a charge jack like the Ernst, but it is a little more deluxe version. The Male-male connector is intended for for use as adapter for your charger or voltmeter lead, however in this case it works great on the other end to connect to the RX in the data port. then the Flight Log device just plugs into it.
Simple, very light and looks good on the side of the model. It has a little plastic door to keep the dirt out of the plug ad snaps shut. The ernst deals are OK but sometimes you have trouble getting the connector to stay in it, and then the little rubber boot for the door always comes unlatched.
These deluxe charge jacks are a little higher end, and work better in my opinion.
A side note I use this port on the side of the model to test voltage...I will turn on the model and use my TX to move controls at the same time applying a loaded volt meter to this jack in the side of the model. This way I'm getting the actual voltage the RX is sending to the servos, along with a loaded baseline of all the servos on and moving , and additional load from my voltmeter. This way I can determine if I have a large enough battery capacity on the model. The data port is on the Servo buss and that means it gets the same voltage the Servo leads are getting.
Troy Newman
Team JR
I use this,
Troy Newman
Team JR
Troy,
Thanks - I pringed the information and should be able to order it this afternoon. You might want to suggest to JR that they package this or something like this with the Flight Log.
Thanks again,
Howard
Thanks again,
Howard
My Feedback: (41)
When I first started playing around with the data logger and the 2.4GHz stuff, I spent some time taking readings and adjusting the placement of my satellite rx's if there were problems. After getting a number of flights where there wasn't anything to look at on the data logger, I just quit worrying about it and stopped taking readings after each landing.
So I'm with Bob now...
I just converted one of my glow models to VPX cells and had a choice of running the balance charge lead into the switch (that makes the signal lead hot and the Spektrum/JR 2.4 rx's don't like that so you can't run the three wires from the switch to the rx...), or keeping the bind/data function at the switch and leaving a short extension hooked to the rx just in the wire bundle inside the model.
I decided to leave the charge function at the switch. Granted on the first few flights where you're looking at the numbers from the data logger it's a bit of a pain pulling the hatch after each flight, but once the rx's are setup I just don't bother with the data logger any more.
{Quote}
{Quote}
I always thought that was its intended purpose. I do likewise.
If you happen to, feel there might have been something wrong during a subsequent flight you can pull the hatch and see.
To check it after every flight (as long as you have a decent set up) falls under "cruel and unusual punishment" in my book.
BTW I have yet to have any in flight anomalies with Spektrum/JR.
{Quote}
My Feedback: (198)
ORIGINAL: Zeeb
Bob,
Zero on everything seems very unlikely. You could get those numbers if you had turned off the power to the RX or TX before checking with the flight log. I would check to see if those results are really valid.
My Feedback: (61)
NJ
ORIGINAL: 1bwana1
Bob,
Bob,
I plug the data logger into a Y cable, and use that instead.
That way I get both male and female plugs for the data logger.
WA
I'm just curious, Howard, how would you have it implemented?
nick
ORIGINAL: seattle_helo
nick
nick
Howard
My Feedback: (198)
ORIGINAL: 1bwana1
Bob,
Bob,
In this particular plane, I have a single remote RX, mounted 90 and higher/aft of the main RX, which is dead amidships and not near (within 10") ANY electronics, battery, etc.
Your question had occurred to me, when I looked..... but I have had "zeroes" post-flight before on other airplanes.
WA
There are likely a number of reasonable solutions to make the Batt/Data RX port accesable from the exterior of the aircraft so that you can simply plug the Flight Log into the remote access and read what it says. One solution would be to include a connector that looks similar to the stand alone JR DSC plug that includes small plastic holder that mounts to the fuselage using a female connector at the fuselage instead of the usual male connector. You could also include a female/female adaptor to use with the existing stand alone DSC cable. Those are two pretty inexpensive options that would make this more convenient for the customer that did not wish to make his own adaptor or take the plane apart to use the Flight Log. Also, it could be incorporated into the switch assembly as a separate plug in just like what was done with the charging jack. It is very convenient to be able to measure the RX battery pack by using the charging jack and ESV - for example.
nick
Is there a definitive listing anywhere on what are typically good bad or indifferent readings from the Data Logger ? A colleague of mine just spent a week flying his CF gliders and other A/C's. He bought the Data Logger and now wishes he hadn't as the numbers all look horrendous to him. It would be nice to be able to point him in the right direction and tell him that the figures he is seiing are quite acceptable for a 15 minute flight.
Ta very much.
Ta very much.
ORIGINAL: GBR2
Can't you just plug a Y harness into the Bat/Data port, hook the battery in on, the logger goes into the other.
Howard
My Feedback: (8)
ORIGINAL: slarty
Ta very much.
Ta very much.
This is from the Spektrum web site:
The Flight Log provides the following information:
System voltage - receiver pack voltage
Antenna fades β represent the loss of a bit of information on that specific antenna. Typically itβs normal to have as many as 50 β 100 antenna fades on any one of the antennas during a flight. If any single antenna experiences over
500 fades in a single flight, the antenna should be repositioned in the aircraft to optimize the RF link.
Frame Loss β represents simultaneous antenna fades on all attached receivers. If the RF link is performing optimally, frame losses per flight should be less than 20.
Hold β a hold occurs when 45 contiguous (one right after the other) frame losses occur. This takes about one second. If a hold occurs during flight, itβs important to re-evaluate the system, moving the antennas to different locations and/or checking to be sure the transmitter and receivers are working correctly.
Replace one of the female connectors on the Y harness with a male and then change the connector on the logger to female. I don't see this as a problem.
