please help me with receiver
Hello
I have Ko Propo Presto EX-11 with receiver KR 297FZ 75Mhz
I need 2 receiver but i can`t find in internet 297FZ 75mhz
Somobody can tell me can i use other receiver(cheap)
for example airtronics 92836 3ch 75Mhz or other ?
RE: please help me with receiver
I believe KO are positive shift, see if you can confirm that in your manual or on the net somewhere. If so, then any 75MHz Positive Shift receiver will work such as this one: http://www3.towerhobbies.com/cgi-bin...?&I=LXKLA8&P=0
Hitec are Negative Shift so that may not work.
Hope that helps
Hope that helps
Hitec has several RX's that are "Auto-shift" and will work with either shift. The problem is finding one on 75 MHz. May be able to buy one in your area or get one modified to 75 MHz.
http://www.hitecrcd.com/receivers/show?name=Supreme+IIS
