Need Help finding Part for JR 10x
I am in need of the little jack in the back of the radio, a piece of jack from a trainer cord got stuck in there and i had to desolder it would let my radio turn off. the brand of it is Hosiden it has 7 prongs that are soldered to a pcb
here is the jack that needs replacing
http://www.hosiden.com/web/frame/products_f.htm the part i need should be in there http://www.hosiden.com/web/frame/products_f.htm you have to agree then click on product catalog, and eventually go to miniature jacks
RE: Need Help finding Part for JR 10x
No, theygive the do-it yourselfer any help.... a long time ago i needed to have a fuse replaced in my tx(this was before i had the balls to open it up my self), and they would not me tell anything.... they said i had to send it in..... its a 3 amp 250 volt fuse
as long as i can find the exact replacement part i can do it my self.... i dont have the patience to wait 2 weeks turn around time to get my tx back.....
TX
Not in a place to look at the moment, but check www.mouser.com - very large electronics supply house, with quick, no minimum orders. May not find the brand, but that's pretty much irrelevant if you find the same contact config . . . .
Is there a part number on the one you took out somewhere? Once you figure out the contact config, the cross reference should be a trivial excercise . . .
- Tim
- Tim
well guy thank you for your time and effort, i really appreciate it. i contacted Tony Stillman of www.radiosouthrc.com has the part on hand Thank God!! There are no secrets there.
