MAN reports on Airtronics SD-10G 2.4Ghz radio system
We are a professional manufacturer of RC battery. which is a high-tech enterprise specializing in the production of Ni-MH, Lithium polymer batteries , all kinds of extension cable and adapter .Our products are mainly used for toys, model aircrafts, ship models, nautical models, electric tools, military products, and other fields.
We measure the parameters of each cell precisely and try to make the targets of cells the same. These lengthen the cycle life of Power battery effectively. Besides, we use special technology in matching which reduce the internal impedance between cells and make the efficiency to the maximum. The battery can be also fit for the discharge of high-current. The products have gained a good reputation for its excellent quality and high performance in the relevant fields. Especially the newly launched Race Series <chmetcnv tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="35" unitname="C">35C</chmetcnv> Continuous Discharge Rate of high power lithium polymer batteries. Its introduction into the market has been widely recognized. Our products sales volumes are risen sharply.
Our company now launches the G4 packs, they are our latest products which have higher performance and more reasonable price. The G4 packs are made of a new Hybrid construction technology, super-fine substrate materials, and final cell matching process, which all guarantee you not only this superb performance, but also tightly balanced and long-lasting packs. The batteries can be safely charged up to <chmetcnv tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="5" unitname="C">5C</chmetcnv> rate, which means the charge will be completed in 20 minutes. They will be your best choice when you checked them out.
If you are interested we could sell them derict to you ,save trading and fast shipping!!For any inquiries please feel free to contact with me
Changchun Hobby-Tec Technology Co.,Ltd
Adds: 13# <place><city>Huiwen Road Nanguan District Changchun City Jilin Province</city> ,<country-region>China</country-region></place>
Telephone: +86-431-85367979
Fax: +86-431-85369822
Website : http://epbattery.en.alibaba.com
Skype on line :epbatteryex
Msn :[email protected]
I cycled the first two or three chareges with an old constant current charger with 1/10C. After that I switched to the supplied charger w/o any problem.
But it´s strange, w/o the charger (and maybe the old analog servo) issue(s) we would not have to talk much about the SD10.
Programming is simple, software and hardware features are above the competitors, FHSS seems to be the best on the market, recivers have the best voltage range down to 2v. What else? The sytems just works flawlessly. Boring, isn´t it?
The Only Problem that I've had with my Airtronics SD-10G, is that the weather hasn't been good enough to take it out and go flying, BUT the weather is supposed to be good this Sat, so I'm hoping that the weather man isn't wrong.[sm=thumbup.gif]
Jim
One thing I'm working on is finding the right feel to the throttle gimbal. I took out the part that makes it 'click' but don't like the feel or the tension without it.
What are you all doing for the throttle lever?
Hi Joe,
I had the same thing. If you take the ratchet away the smooth throttle is too loose even if the tension plate is fully tightened.
What i did was flip the ratchet tension plate upside down. This gives you a smooth throttle with the ability to achive more tension.
There is also a stick stop mod which shortens the throttle stick travel by 1 of the marked gradutions each side. All you need for this a old servo wheel and a couple of 2mm or 2-56 cap screws with a washer (or 2).
There's more info and pictures of the stick stops at H E L I F R E A K .com
Look for Finless Bobs Tech room and the thread on the SD-10G. Its somewhere around page 26 off memory.
Mike
Has anybody tried the extra springs that came with the radio yet??
My one and only gripe after 5 months is that the TX battery connector is darn- near impossible to wiggle free. I trimmed it a bit, but it's still tight. Backup Eneloop connector is even worse.
I had the same complaint about mine. I just knew that I was going to pull the wires out of the battery plug trying to un-plug it. So I plugged a 3" servo extension in to the battery port on the Tx. Then plugged the other end into the battery lead. Problem solved. Just be sure to observe the correct polarity on the servo extension when plugging it into the battery port on the TX and then into the battery.
Once the servo extension is plugged into the battery port, you don't have to mess with trying to get your battery un-plugged from the stubborn battery port on the Tx, Just un-plug it at the servo extension end.
Jim
Yes, I put mine in and it feels much better with them. Of course it sucks that I have to send the whole thing back since I get no range with the 7 channel RX.
On the range check you know they were having issues with some of the smaller RXs, right? Its not really a problem you should probably ask before you send it back in. Slats
Thanks I tried them out and yes they do make a difference, feels great, I could never get the DX7 that I had to this level.
It sounds like to me you have something blocking the signal at a certain orientation. At the point where the plane locked out, is there a battery or such lined up between the antennae and you?
Garret
You mean the "SD-5G"? I did not hear they were coming out with a 6-channel TX...
Garret
Thanks, Duane
