MAN reports on Airtronics SD-10G 2.4Ghz radio system
#677
My Feedback: (21)
PA
RE: MAN reports on Airtronics SD-10G 2.4Ghz radio system
ORIGINAL: theSteam
Hi Folks,
I am at a loss as to where to post my question. Since I have posted here before... and had good helpfull responces...
I bought an Easy Glider Pro. All servos came installed... I cannot for the life of me as a beginner with E-Flight, figure out how to mount the motor. So many parts, ZERO instruction. I searched this site top to bottom.
Where can I post my, ''How do I assemble the motor'' question to get a proper responce?
Douglas
P.S. New to forums as well as E-Flight.
Hi Folks,
Douglas
#678
My Feedback: (55)
After reviewing and spending much time with the Hitec A9 I began looking again at the SD-10G including visiting the airtronics.net website and Hobby People website. I am sure that I am joining this effort in the middle of the party but, it is hard to tell if the airtronics website is being constructed or being torn down with respect to the SD-10G it is worthless. The Hobby People website says to go to the airtronics website to download SD-10G software but I was not able to find it. I just finished rereading the SD-10G manual and it is certainly an extremely capable and flexible radio but I honestly can't tell if things are going downhill or going through growing pains on the way up. Can someone lend me a hand so that I can get on the right path or inform me where my observations are not correct. Thanks
Howard
Howard
#679
Yes, the website is still under development. Soon we will start updated content. It has simply taken longer than expected to build the infrastucture for it. Please call the 800 number if you have tech questions.
#680
Has anybody else downloaded their models to their PC from their SD-10G?
Is there any way to read/edit those files? I didn't get an ap on the disk to do this.
How about FLASH updates? Anybody heard if anything is in the works?
#681
Hello,
I am setting up an Easy Glider Pro electric sailplane. I tried using the "Sailplane mode" to set it up. However, the thottle would not operate the motor. I am new to electric flight. I did switch the transmitter to "Aircraft mode" and verified the motor runs from the throttle but this takes away some of the programmable functions available in "Sailplane mode".
Under channel assignments in Sailplane mode channel 3 was listed as MT (motor).......
So,is there a wayto make the electric motor run from the throttle stick while using Sailplane mode?
Any help from anyone... as always to be appreciated and passed on.
Douglas
Douglas
#682
You can use the flap stick to operate the motor and use the VR assign menu to change the flap function to a VR slider...
Sometimes, for simple sailplanes, it´s easier to user aero mode...
#683
My Feedback: (41)
ORIGINAL: grotto2
#685
My Feedback: (37)
I've had my SD-10G now for over 9 months and and can't say enough good about it and how Airtronics is supporting us. We now have 4 10G's in our small club here in Oklahoma.
One of the problems I have had is remembering what I assigned to each switch (lots of switches!). I always put the basic stuff (Flaps and retracts) on the same switch but when I add some of customized programming the 10G allows I sometimes can't remember which switch I assign the function to. To help me keep the switches straight, I scanned the transmitter drawing from the manual, imported the image into my cad program, and then added switch labels to each switch. Here is how it came out. Now I just write in the functions on each switch and tape that to my flight log book.
If anyone wants a clean JPEG or cad copy shoot me a PM with your email address.
#686
ON, CANADA
ORIGINAL: gsmith6879
I have the same problem! Please send me a JPEG ... PM sent.
Colin.
#687
Had the radio a few months now - excellent. Love the switch flexibility.
I'm only working in Aero Mode. Cant figure out where S5 is? Also what do T5 and T6 do for me in Aero Mode? Can I select them anywhere? Anybody any ideas?
#688
My Feedback: (12)
AP
Got my 10g today and I have been playing with it, love the software. I did notice that mine does not have the antenne extension that I have seen on others. Who has the best price on recievers?
Anyone had any problems?
Have a nice day
Have a nice day
#689
My Feedback: (21)
ORIGINAL: bigbuster
Have a nice day
Have a nice day
#690
s1 through s5 are your stick switches. You can assign them to any function and any stick movement. the trims you mention are for heli only. in aero mode they do not do anything
#692
It's not a matter of stick "axis". Each stick switch being used is a "position" on whatever stick, in whatever position, you want it to be.
If you need a more detailed explanation, call the 800 and let Jack walk you through it. If you've never used it before, it might need a more detailed explanation. I didn't get the concept the first time someone told me about it either.
For those customers with Airtronics technical and setup questions
Airtronics offers a toll-free help line.
You can reach an Airtronics expert at 1-800-262-1178 Monday through
Friday 12pm to 4pm Pacific Time.
Jack is there to help!
Mike
Mike
#694
My Feedback: (43)
ORIGINAL: MikeGreenshields
I would love to see T5 and T6 be turned into real switches. They are in a great place for funciton like lights, canopy open/close, tail hooks etc. Could that be a possible software upgrade?
#695
ORIGINAL: JeffH
Mike,
#696
Wasn't there a discussion here of grinding away some of the plastic on the case for folks with small hands ? I seems to recall that subject but now can't find it.
I visited a Hobby Shack the other day and took the opportunity to hold the SD-10G transmitter. As I feared, my hands aren't large enough to easily move the sticks through their full travel.
Dick
Dick
#698
ORIGINAL: mups53
Dick have you considered a transmitter tray? Mike
Mike,
Thanks for your suggestion. I did try a tray years ago and found it to cumbersome and potentially dangerous when starting my planes. Guess 50 years of thumb flying is a hard habit to break, especially when there are lots of quite acceptable radios that are thin enough to fit my hands.
Dick
#699
ORIGINAL: otrcman
Dick
Dick
Is there another 9/10/12 channel radio you've held in your hands that you think is a better fit for you, otrcman?
#700
I am not a particular big guy (understatement..) I would not say my hands are very big. The only radio I was ever not able to hold right was the old Infinity 1000. I fly the SD10G (obviously) with no trouble. It took me about 30 minutes of flying to get used to it. I hold it a little differently I guess than I did some of the other radios, but have no trouble (or no more trouble than any other radio) moving the sticks through their entire travel.
Also note the switches are space differently ( a little farther apart) for those who fly with their 3rd and 4th fingers up around those switches (usually the thumb/finger together flyers do this).
No one radio is going to fit all hands, etc. But in my hands, which are on the smaller side, I don't have any problems.
-Mike
-Mike
