Hobbico Digital servos w/Futaba servo arms
I recently bought 4 Hobbico CS-140's digital servos and was surprised to find out that only short servo arms were included. My other (analog) Hobbico servos like the CS-64 and CS-70 came with long servo arms. My biggest surprise was to find out that unlike the analogs, Hitec servo arms will not work with Hobbico digitals. I called Tower Hobbies and they told me I could use Dubro long servo arms for Futaba so I went to my LHS and bought some but I noticed the fit is not as tight as my other servos (mostly Hitec or made by Hitec). Has anyone experienced any problems with these Hobbico digitals/Dubro for Futaba servo arms combination?
My Feedback: (17)
TN
RE: Hobbico Digital servos w/Futaba servo arms
Some Hobbico servos are made by Hitec and some are made by Futaba. Make sure you find out what exactly you have and use the appropriate arms, because some arms may fit, but will slip, and if that happens in the air, you know the end result. If you don't know who made the CS 140, count the splines on the output shaft. I don't know which one is which, but between Hitec and Futaba one has 24 splines, the other 25. So count the splines on both the arms and the shaft of the servo, and if the same, you are all set.
ORIGINAL: Planeclothes I recently bought 4 Hobbico CS-140's digital servos and was surprised to find out that only short servo arms were included. My other (analog) Hobbico servos like the CS-64 and CS-70 came with long servo arms. My biggest surprise was to find out that unlike the analogs, Hitec servo arms will not work with Hobbico digitals. I called Tower Hobbies and they told me I could use Dubro long servo arms for Futaba so I went to my LHS and bought some but I noticed the fit is not as tight as my other servos (mostly Hitec or made by Hitec). Has anyone experienced any problems with these Hobbico digitals/Dubro for Futaba servo arms combination?
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
