Two servos on the rudder, one on each side?
OH
Hi all,
I have a Sig Sukhoi (or Suki as it's known around my house now, thanks Terry) and notice that it has a servo bay on each side of the fuse for the rudder. Can you put two of the same servo on opposite sides and not have them fighting each other? I'm thinking Hitec 645MG's. Would I be better off with a standard pull-pull system? Any info would be great!
IronZ
IronZ
OH
I've got the 9CAP. I know I can "y" the servos or mix it with the radio. I just didn't know if you could actually put two servos opposite each other and have it work nice and smooth.
IronZ
IronZ
My 35% Giles is set up this way. I use two 5945's, one on each side. I used the hitec programmer to reverse one servo and also to match their output. Setup was very easy and the rudder has plenty of authority.
Depends on how the plane balances. If it is tail heavy pull-pull may be the way to go. I'd use one large servo such as the futaba 5050 or 5301,hitec 5735 or 805, even the jr 615 would work.
The 9C has a mix already set up for dual servos on the elevator. I think its called elevon... you can set it up for elevator both halves move up and down together and you can also have them move opposite directions like the ailerons.. in conjunction with the actual ailerons. Just zero the aileron movement and get the right deflection directions on the elevator setup. I believe the manual has some directions on this setup.. I don't remember exactly but I think you use channels 7 & 8 for this. Of course you can always use a couple of mixing channels also and one servo to the other. It is a nice way to set up the elevator and easy using the elevon function.
