Wanted Synthesized Trans and Receiver on 75 Mhz
MI
I need a working Transmitter and receiver on the 75 Mhz band
both with systhesized channels. Hitec Transmitter and Novak receiver would be great.... Futaba expensive.
Need not be in excellent condition. Servos not needed
Working on a project to build a frequency scanner for club use.
When its working , I will then build one for 72 Mhz
UT
Or you could buy a synthesized system which has the scanner built-in. There aren't very many fully synthesized systems available in North America, so your search for a used one will be a hard one.
The Tracker II from Polk's Hobbies (www.polkshobby.com) is available in 72, and 75Mhz for $275
It's features include:
- Fully digital system (every stick, knob, and switch has 1024 step resolution)
- Fully synthesized transmitter and receiver, with no dials to wear out
- 99 model memory
- 3 programmable 2-way mixes in addition to the integrated mixes
- Excellent customer support - they even changed the programming based upon our requests
- and more...
To read about it in extensive detail, check out the thread There is a Tracker II where owners like me have been answering any questions people have on this new radio..
- 99 model memory
- and more...
