Strange GWS reciever problem
I picked up a 4 channel GWS reciever today and am having a strange problem with it.
Chennel 4 doesn't work. When I plug in a servo I get a twitch but no responce to inputs. Also if I try hooking the battery up to this channel then I get no power at all. I am honestly at a loss. The other three channels work fine.
Sounds like the ground or power or both pins are not making connection at the board. Use a magnifying glass and see if you can find the problem. Should be right where the pins are. If you do, be very careful in soldering them.
