How do I program ailerons up with up elevator?
I have a Futab9c FM radio and a 127 DF Futaaba receiver. I have air brakes, ailerons up , with low throttle. On the same switch I have ailerons up elevator down and vice versa. In the middle of this 3 position switch nothing is mixed. How do I alter this so that I can flip another switch and have up ailerons mixed with up elevator? I saw another guy do this with this same radio and I thought I could figure out how to do this but I can't. HELP.
You can either use the built-in elev-flap mix and assign it to your desired switch or you can do two pmixes; elevator-aileron1 and elevator-aileron2, and assign those mixes to your desired switch.
