Futaba 9CAP
AR
Futaba 9CAP
I just stumbled across a Futaba 9CAP radio system for sale. What are the pros and cons of this system? I know this can't be compared to 2.4 systems, but how does it compare with other 72 MHz systems? Thanks, folks.
RE: Futaba 9CAP
I've got both the 9CAP and 9CAP Supper. The later has a couple more mix capibalities, but unless you are pushiing the limits, you wouldn't know the difference. The 10C is a followon to this series and all three share the plug in modules that can be any of the R/C bands, IE 35mhz, 72mhz 2.4, and the ham bands in the US, 52mhz I think they are. One Tx will work on all of the with different modles. Probably the most versitable TX on the market today. Well yesterday. The only complaint I have is cosmetic, the silver coverring on the face tends to bubble up and wrinkle. My 9C looks like an aligator skin.
Don
Don
RE: Futaba 9CAP
I had my 9CAP for a couple of years and then came across the JR XP9303.
The 9CAP has 8 proportional channels and a 9th channel that is only a switch and only works in PCM. If you add a 2.4 module, you only get 8 channels.
The 9303 has 9 proportional channels. You can buy the cheaper 9ch PPM Rx and still have 9 proportional channels. The 9303 has Flaps on a Switch, by default. The 9303 has Flight Modes which you can put on a 3 position switch and vary all the parameters in a Model Memory, for each of the 3 Flight Modes. You can obtain a Spektrum 2.4 RF module and still have 9 proportional channels on both 72Mhz and 2.4.
If you opt for the JR X9303 2.4, you can't switch to 72Mhz, but you get all the other features of the XP9303, plus, you get Model Match and Servo Sync. Model Match means you cannot use the wrong Model Memory, by accident, because when you Bind a Model Memory to an Rx, it will not work with another Rx. The X9303 is faster than the XP9303 because among other things, it has less Latency.
I think for a 9 channel radio, the 9303 blows away the 9CAP, but if you get a good price, the 9CAP is still a good radio
My Feedback: (48)
MI
RE: Futaba 9CAP
RE: Futaba 9CAP
ORIGINAL: tande
Really! "Futaba" says they never heard of it.....(mine too!)
In regards to the original question, as others have mentioned, the 9C is great. I have been completely happy with mine, which I purchased shortly after they came out (2002?) It is easy to program and has all of the features that will keep all but the best happy.
