Difference between 3 & 5 pole motors?
I was just curious what the advantages are overing having a 5 pole motor in a servo over a 3 pole motor?
Thanks for the help ,
Brian
Brian
NE
5 pole motor has more "steps" in one revolution. This generally means a 5 pole motor runs smoother and can more accurately hold a static position compared to a 3 pole motor.
With respect to servos, you can't really judge the smoothness or precision by what motor is used because other factors come into play, such as pot accuracy, deadband, gearlash, etc. However, it has been my experience that the manufacturer will use a better motor in it's better performing servos, i.e. servo with a coreless motor will probably perform better than a servo with a 3-pole motor.
I think there was a lengthy discussion of motors with respect to servos a few months ago. You might try a search.
Cheers.
Cheers.
With respect to servos, you can't really judge the smoothness or precision by what motor is used because other factors come into play, such as pot accuracy, deadband, gearlash, etc. ...
Cheers.
Cheers.
This may not go along with the subject of the thread, but how can I find out a servo's deadband and/or pot accuracy? I'll make sure to do a search on those key terms also. I figure since it came up, I just might as well ask how I can find out which servos have all the right qualities. <--- If that servo even exists
-Brian
