E-Flite Blade CP Tx Compatability
Has anyone every tried using the Tx that comes with the Blade CP with any other Rx. I've just inherited a plane from a friend of mine but don't have a dedicated radio system for it. I want to buy another Rx for it and just used the Blade's Tx. Is this possible?
RE: E-Flite Blade CP Tx Compatability
NO. The blade CP's TX has CCPM built in to it. That means that when you move the right stick in any direction, it doesn't just affect the direction you move it, it affects channels 3, 4, and 6, because in a CCPm heli, there are 3 servos that work in unison to control the heli, and movement in one channel, is mixed in with the other two channels. basically, the movement of channel 6 wouldn't be a problem, but when you used the elevator, it would also affect the ailerons or rudder (whatever you have hook to that channel) and vice verse.
Hi,
I'm flying Blade CP Pro 2 with HP6DSM. Yes, indeed it uses CCPM but this can be deactivated (see manual page .. 32 ?)
.. using the Tx for Phoenix Flightsim and only had to deactivated the DIP switch...
Regards from Germany,
Stefan
Stefan
