Futaba 9CAP receivers question
RE: Futaba 9CAP receivers question
The 9C will work with any receiver, on any band that you have a matching TXRFmodule for it if it is compatable with the shift used by Futaba.. IE if you have a receiver with a shif the same as futaba uses. on 72mhz, reguradless of PPMor PCM, as long as you have a RMmodule on the same frequency, it will work. It doesn't support AM, but it will support 2.4Fasst. It is very flexable. Here in the us, modules are only avaiable for 72mhz, Lower Ham band, and 2.4ghz. as those are the frequency's we can use. In Eurpoe and elsewhere, the modules are avabial for that regions frequencys.
Don
Don
ORIGINAL: Campgems
Don
Don
Which 2.4 Fasst module is compatable with Futaba 9C?I know Futaba has 7 , 8 and 10 channels RX/Tx Fasst modules and 10 channels transmitter module
You can use either the TM-7 or TM-8 module with the 9C. Tm-10 will only fit the 10C.
There is no 9 channel module, since Futabas PPM output is limited to 8 channels.
Pete
Pete
ORIGINAL: pilotpete2
Pete
Pete
You mentioned 40 mhz. Are you planning to use the transmitter in the USA? If so, you cannot use 40 mhz.
You can use 72 or 50 mhz for aircraft. You need an FCC license to use 50 mhz.
You can use 75 mhz for surfasce models. Not sure about 50 mhz.
Futaba receivers compatible with 9C (must have correct transmitter module)[50, 72, and 75 mhz]
http://www3.towerhobbies.com/cgi-bin...SM&C=LDN&V=FUT
http://www3.towerhobbies.com/cgi-bin...SM&C=LDQ&V=FUT
You can also use 2.4 ghz spread spectrum technology by getting a transmitter module/receiver package from a variety of manufacturers
Futaba 2.4 ghz module and receiver packages compatible with 9C
http://www3.towerhobbies.com/cgi-bin...&I=LXUMU0&P=SM
http://www3.towerhobbies.com/cgi-bin...&I=LXXDP9&P=SM
Spektrum 2.4 ghz module and receiver packages compatible with 9C
http://www.horizonhobby.com/Products...odId=SPMMSFUT7
http://www.horizonhobby.com/Products...odID=SPMMSFUT9
XPS 2.4 ghz module and receiver package compatible with 9C
http://www.xtremepowersystems.net/pr...rod=XPS-CPF2-8
ASSAN 2.4 ghz module and receiver package compatible with 9C
http://assan.cn/main/product_24Ghz_all_en.html
