PowerBox Digi-Switch
Hi All, just got a PowerBox Digi-Switch and have a quick question about it. In the manual it says that the default setting for the switch is on when a power source is connected which doesn't seem to be the case.
If the switch is on before it is disconnected it will be on when the battery is reconnected
If the switch is off before the batt is disconnected it will be off when reconnected!
Is this normal?
Is this normal?
RE: PowerBox Digi-Switch
Hello Dale,
I happened to have the same situation, did the same test you did with the same results, so yes , it's normal, I have three of them and they all behave the same way.
Regards
Regards
