Hitec 5625 servo play
I have a pair of 5625 sevos that have been in service for about 5 year on my Fusion 67" ailerons. I recently was flying and had a a large amount flutter on the ailerons and when I brought the plane down I noticed a significant amount of play in both servos. Hard to measure but I would guess it's a couple of degrees. I changed all the gears however the play is still the same.
Any thoughts on what else should be replaced? Dave |
RE: Hitec 5625 servo play
The pots are worn out. Send them back to Hitec for replacement
ORIGINAL: dszabo2 I have a pair of 5625 sevos that have been in service for about 5 year on my Fusion 67" ailerons. I recently was flying and had a a large amount flutter on the ailerons and when I brought the plane down I noticed a significant amount of play in both servos. Hard to measure but I would guess it's a couple of degrees. I changed all the gears however the play is still the same. Any thoughts on what else should be replaced? Dave checking the photo attached: . Servo - FAQ : Metal Gear Servos - DIY Repair & Extend MG Servo Gear Life . Servo - Burnout. Cause & Prevention . . Servo - DIY Repair - Lubrication (servo grease) Much more information available under sub sections "Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures" "Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ." below "Radio Systems, Accessories, Alterations and FAQ" at Alan's Hobby, Model & RC FAQ Web Links Alan T. |
Very lucky to even have the plane to put servos in!! Buy new servos. Take no chances..
ORIGINAL: warbird72 Very lucky to even have the plane to put servos in!! Buy new servos. Take no chances.. Just replacing the pot and the gears will make a new servo out of it. It may be Hitec will decide to just send you a new servo at 1/2 the price instead of fixing it. |
Check the case tops where the second pin is supported... if this is worn is can cause slop.
Mike. |
Whats the deal on that pin Mike? I have a servo where the pin worked its way thru the case. Obviously the servo quit. I glued the pin back with thin CA. Dont know if I trust it though.
Are new case tops available? |
You know!! I have really never see the reps get on a site to try to resolve stuff. AAA+++ Hitec!! Keep up the great work. My eclipse 7 still going strong after your repair.. Thanks Mike..
Hitec makes servos at all levels... the high end products like the 7954SH and up use brass bushings to support the pins since they have much more torque. Just as gears can wear, cases can wear as well so you should check for this over time to be on the safe side. Worst case scenario is that the pin can move so much that it locks up the gear train.
Mike. |
Mike
Thanks for the advice on the pin. I took the servo apart today and the hole in the case seemed to have a relatively good fit to the pin. However when I manually rotated the servo arm with the case off I was able to see how the center pin deflects. I was getting the same slop with the case off as when it is on. Based on the fit into the case I cant imagine the pin being able to move at all. How deep the the pin engage the case?? I have $18 already invested in the repair and the case is another $7. That's more than half the cost of a new servo. Dave |
<span style="font-size: smaller;">ORIGINAL: dszabo2 Mike Thanks for the advice on the pin. I took the servo apart today and the hole in the case seemed to have a relatively good fit to the pin. However when I manually rotated the servo arm with the case off I was able to see how the center pin deflects. I was getting the same slop with the case off as when it is on. Based on the fit into the case I cant imagine the pin being able to move at all. How deep the the pin engage the case?? I have $18 already invested in the repair and the case is another $7. That's more than half the cost of a new servo. Dave</span> Pin should be a tight fit into the case which is well documented with photos and information on shaft wear, under: . Hitec - HS-225MG & HS-5245MG "How to make a good servo a great servo Much more information available under sub section: "Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ." below "Radio Systems, Accessories, Alterations and FAQ" at Alan's Hobby, Model & RC FAQ Web Links Alan T. |
Thanks to all for the help. I will replace the center shaft per AT recommendation
Dave |
