Kwigen |
03-13-2014 10:29 PM |
Aileron and rudder trim is reversed on T8FG
I had a rather interesting flight today. My first flight on my old Dazzler with a T8FG trans and a R617FS rec. After takeoff I needed a touch of left trim, bumped the button a couple of times, things got interesting quickly. I decided I had a linkage problem and was able to land safely. What I found was that trimming left moved the ailerons to the right. Same problem with the rudder. I can find nothing in the manual about reversing trims and I cannot think of a time when you would want to do that.
I've flown the radio in other planes, this is the first time I've had this problem.
