I'm going back...tired of all this binding crap
1 Attachment(s)
Attachment 2272137
so....I have this equipment to use for starters. I will get new tx batteries, but I want to use the newer smaller servos, like a bunch of EMX-ES08E. They weigh in at 8gm. Will they work? and the brushed can motors, seems I have a few 300-400 size....what is the motor controller AMP size for these? And flight battery pack size? i have Spitfire and bf109 plans........ please help, as my idea is flying outta the local cow pasture, frequency's and weight isn't a concern......wishing I had my old blue hobby lobby radio! marc |
Hi Marc,
While your Futaba "Conquest" will be fine to use, your Futaba FP-6FN is not FCC legal unless it's been "Narrow Banded" by a place like "Radios South" or similar. Quite some time ago the FCC changed the 72 MHZ spec from wide band to narrow band, and at the time all of the narrow band TXs had a little round gold sticker that indicated they complied with the new standard. Here is an excerpt from an online source describing the change from wide to narrow band; " In the 72 Mhz band, each frequency channel was separated by a 80 kHz margin. For example, the first frequency was known as 'brown and white' and was situated at 72.080 MHz, the next was 'blue and white' at 72.160 MHz, etc. The receivers that could 'listen' to these frequencies with this 80 kHz spacing are known as Hetrodyne receivers or 'wide-band'. In 1988, the frequency spacing of the radio frequency channels was reduced to 20 kHz which turned the original 6 frequency channels into 50 channels. At this point in time, the frequency flag mechanism was abandoned and each frequency channel was assigned a number, starting at 11 (72.010 MHz) and running to channel 60 (72.990 MHz). What's important to note is that the original 6 frequencies fall in between the newer, assigned channel numbers, and are sometimes referred to as 'half-channels'. At first, only the even channel numbers were available." So, with that outta the way, fly the Conquest and keep the earlier FP-6FN as a display piece. The modern servos you want to use will work with the Conquest system and a "300 to 400" sized brushed motor shouldn't need more than a 40 amp ESC. Lastly, I've got quite a collection of antique TXs as display models, is this the Hobby Lobby TX you had? https://cimg9.ibsrv.net/gimg/www.rcu...8791b1d559.jpg https://cimg0.ibsrv.net/gimg/www.rcu...ef274143c6.jpg |
PS, I just noticed you posted this thread in the "Futaba radios direct support forum" instead of in the general RC radios section. Here, no one is supposed to answer except the Futaba representative. I have been told in the past not to answer questions here, and my bad, I didn't notice the subforum you posted in till after I answered you. If you want members other than the Futaba rep to respond, perhaps having the Mods move your thread to the general radios area will prompt more responses.......
. I have been told in the past not to answer questions here...
one more 'rule'.....I AM a rule breaker! YES! That's my old blue dear friend!...best radio I ever had.....ihopeto run across one to buy someday....as for the FCC....COME ON AND GET ME!!!.....I'll be feared in the prison block!.."watch out for that new guy, I heard he's in for FCC rule breaks". Bahaawawahahaha...... in tenn you can fly n a cow pasture still, no weight limit, no frequency laws.....heck, you can even carry your fav hip pistol.....nobody cares..... thanks for the info info about the gear, I found my Mig 3 plans for 049 size motors...so my can motor with BEC should do great. These are the plans that Eric Clutton drew up.....I miss that ol guy, AND his ever present parakeet! marc |
Bounced this to the general section since it's really not a support issue for Bill
Originally Posted by kaintuck
(Post 12739756)
Originally Posted by BarracudaHockey
(Post 12739757)
Originally Posted by init4fun
(Post 12739766)
...Being so rural of course you'll never be visited by either the FCC or the FAA, because there is no one else around to be involved in any incident involving your plane...
As far as the op's question, no reason at all you can use the newer servos. AFAIK all digital servos still accept analog inputs.
And what's the big deal about binding. Stay with one manufacturer. I use FlySky and its sub brand Turnigy. They provide bind plugs but you don't need them on the i6S, i10S or 9X. The i6S is a pain with model memory because it doesn't "remember" the receiver by model, but rebinding is simple. The i10S manual says you can bind different receivers by model number. I used to have a Spectrum DX6 and was glad I only had one airplane bound to it. Expensive PITA transmitter. |
(Post 12739757)
I think of note here is the standard has been for a long time the 1500 micro pulses for servo centers. Will it change?
I have one of those MRC's in my collection. I think those open gimbals are so good looking. It came in it's own hard vinyl case, still works (don't tell the FCC). |
what, no EK Logitrol...
Originally Posted by mongo
(Post 12739915)
Oh, jeez. Please give us a break and just go.........
(Post 12739918)
I'll bet there's one in a box around here somewhere, That's the great thing about buying a new house, every moving box ya open is like Christmas :D
We're gonna need a bigger boat. Nah nah!
Originally Posted by rgburrill
(Post 12740019)
You're gonna need a bigger shelf.
Originally Posted by kmeyers
(Post 12740059)
(Post 12739757)
Andy |
Originally Posted by AndyKunz
(Post 12740472)
Bill died in December.
Andy I meant the other Bill (Futaba-RC) but thanks for letting me know. |
I had some fun learning to fly my first ever 5ch. RC model on this 4ch.radio, Th/Coll. off one 'F148' servo, no gyro, LOL now. Those were the days.
https://cimg2.ibsrv.net/gimg/www.rcu...3b775379cd.jpg I cut those long stix down to 10mm soon after to get more controls. https://cimg6.ibsrv.net/gimg/www.rcu...a294a364b4.jpg Even made a special starting jig, LOL. https://cimg9.ibsrv.net/gimg/www.rcu...bd50b27d98.jpg Another fun this morn with my 25YO TX. Bit of battle in the wind with this little one, LOL. |
Everything here is Futaba, at least 25 years old and on 50 mHz. We dont need no steenkin 1991 steeckers:D
Nothing wrong with Futaba, my first 2 radios were the "F", nowdays preffer, JR/Groupner's "MX22" , the best TX I ever had, still using 2 of them on 36 and 2.4 by changing the back module, a brilliant idea, you can't do with any current radios as my latest "Spektrum DX9", pretty good but no match to MX.
https://cimg0.ibsrv.net/gimg/www.rcu...8d7744d80b.jpg Easy swap of freq. https://cimg2.ibsrv.net/gimg/www.rcu...59c1ee5b68.jpg The first TX job is to cut down the stx to 10mm for better controls. https://cimg3.ibsrv.net/gimg/www.rcu...8373dfa1a6.jpg I preffer the left, it's lot heavier, feels like a real radio. |
Gee that MX22 looks exactly like my JR 9303's.
I heard way back in the day that "Spectrum" (because they didn't know how to market) made all of JR's stuff (and they had a lovers tiff). I wonder if that would hold for those MX radios. |
Actually, JR built some of our early radios for us, certainly not all. JR licensed our DSM2 and DSMX technologies for use in their products sold in the USA. In Europe they were hogtied by other contracts that limited them.
BTW, it's spelled with a K, not a C. Spektrum. Andy |
[QUOTE=kmeyers;12741480]Gee that MX22 looks exactly like my JR 9303's.
The casing might look alike but with Groupner software it was more advanced. Both of mine after daily use got some algee germinating on outside casing to make it look more authentic, LOL. |
Andee
I going to stick to the rumors, they are more fun then the facts. I have always had trouble with spelling. I'll tri wurking on it. |
(Post 12741645)
Andee
I going to stick to the rumors, they are more fun then the facts. I have always had trouble with spelling. I'll tri wurking on it. But than again, this is an International site, representing dozens of nations. Zdravstvuj tovarishch, ponimajesh po Ruski? LOL. |
Originally Posted by Joseph Frost
(Post 12741672)
When you speak and communicate in more than 3 lingos the spelling is always bit of a challenge, LOL, I get huge entertainment after reading some posts by our US posters and their spelling, LOL.
But than again, this is an International site, representing dozens of nations. Zdravstvuj tovarishch, ponimajesh po Ruski? LOL. I actually try to use every piece of equipment I own until it has no useful life left. Here in the USA a long time ago there was a saying in education, " The three R's" (reading writing and arithmetic ). Looking for a catchy phrase not too long ago by anti-pollution groups, a new 3 R's came along. Reduce, reuse and recycle, which now is one of my mantras. My post was to be humor toward myself and the "rumor" about JR and Spektrum that I had heard. Where I live in Illinois we run into people who deal with Horizon Hobbies often. Then AndyKunz's reply which is more fact based, had me going for more humor to include misspelling. The funniest thing is that I do not find binding to be difficult. Maybe I should say I am sorry for my posts in this thread to the OP. Ooops |
(Post 12741672)
..... Zdravstvuj tovarishch, ponimajesh po Ruski? LOL.
(Post 12741768)
+1 to this post.
I actually try to use every piece of equipment I own until it has no useful life left. Here in the USA a long time ago there was a saying in education, " The three R's" (reading writing and arithmetic ). Looking for a catchy phrase not too long ago by anti-pollution groups, a new 3 R's came along. Reduce, reuse and recycle, which now is one of my mantras. My post was to be humor toward myself and the "rumor" about JR and Spektrum that I had heard. Where I live in Illinois we run into people who deal with Horizon Hobbies often. Then AndyKunz's reply which is more fact based, had me going for more humor to include misspelling. The funniest thing is that I do not find binding to be difficult. Maybe I should say I am sorry for my posts in this thread to the OP. Ooops Lots of posts and replies can be read by different people in different ways, often creating can of open worms or opening a bag of poisonous snakes, LOL. I also find binding very simple if the correct procedure is followed with correct equipment to match. |
(Post 12739740)
Attachment 2272137
so....I have this equipment to use for starters. I will get new tx batteries, but I want to use the newer smaller servos, like a bunch of EMX-ES08E. They weigh in at 8gm. Will they work? and the brushed can motors, seems I have a few 300-400 size....what is the motor controller AMP size for these? And flight battery pack size? i have Spitfire and bf109 plans........ please help, as my idea is flying outta the local cow pasture, frequency's and weight isn't a concern......wishing I had my old blue hobby lobby radio! marc Sorry I don't see enough info about plane size and weight for other recommendations. IMHO |
