Need HELP!!!
I just got a new JR 9303 2.4ghz and I cant find were to set up dual elevators. Can anyone tell me what page its on or how to do it.
RE: Need HELP!!!
Hook up 2 Servo Aileron non Flaperon
#1. Go to DEVICE SELECT and rotate the roller until you are under AUX2 (on the bottom of the screen), Press the roller and INH AUX2. #2. Go to WING TYPE: NORMAL and rotate the roller until you are under AILE, Press the roller and select AUX2. Hook up 2 Servo Elevator #1. Go to DEVICE SELECT and rotate the roller until you are under AUX3 (on the bottom of the screen), Press the roller and INH AUX3 #2. Go to WING TYPE: NORMAL and rotate the roller until you are under ELEV, Press the roller and select AUX3. NOTE: You may have to REVERSE AUX2 OR AUX3 or both depends on the hookup of the linkage. NOTE: Connect Right Aileron to Aileron and Left Aileron to Aux2. The same for the Elevators Right Elevator to Elevator and Left Elevator to Aux3. |
RE: Need HELP!!!
The short answer to your question is page A-14. codimasta, though, has probably done a better job of the explanation.
RE: Need HELP!!!
Thanks for all your help codimasta and airbusdrvr.
