RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   Hitec Eclipse Retracts Problem (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/837510-hitec-eclipse-retracts-problem.html)
jwl 06-06-2003 02:38 AM
Ok here is an interesting problem.
My TF P-47 is set up with (bought it built and ready for flight) the landing gear on mechanical retracts. Two futaba retract servos running two mech retracts (one servo for each retract).
When I y-harness them together and plug em into the receiver and throw the switch,.......one gear leg goes down, one goes up. Throw switch other way and opposite happens.
I can't get both legs up and down at the same time!
It's probably a really silly fix, but my manual (radio) is missing and in need to get this straightened out.
Any ideas?
Jeff
jneesy 06-06-2003 02:46 AM
either reverse the servo horn on one of the servos , or turn one of the servos 180* or buy a servo reverser.
jwl 06-06-2003 02:49 AM
See.....I knew it was a silly solution, it must be past my bedtime!
Thanks!
