Inferno GT2 Using Futaba 4PL help
NJ
Hello,
I just recently picked up a Kyosho Inferno GT2
When I got the car the first thing I did was swap out the reciever and replaced it with a Futaba R2104GF. I did the same with my Traxxas Slayer and the truck performed fine. The GT2 seems like the brakes are applied the whole time even when the servo is in neutral position. The car also does not accelerate properly. I've been messing with the settings on the transmitter all day and can't seem to get it right. Does anyone have a 4PL and could you please give me suggestions on the settings please. I have not made an engine tuning adjustments today was the first startup and run.
RE: Inferno GT2 Using Futaba 4PL help
Check if the brakes are actually actually on...if they are then adjust the linkage...if they are not then find what is binding.
