Ntc3 fuel Problems
Ntc3 fuel Problems
I m sure that this has been answered a 1000 times I am probley not using the right words in the search. My problem is that when Iam running at high revs the gas just pours out of the tank through the pressure side. Are there any good fixes for this because at this point a full tank only lasted about a minute.
RE: Ntc3 fuel Problems
thats like my old primerless tank..i think it has somethin to do with the pressure line.. needs to be shorter or longer not sure but mines is super long.. its either that or you dont have a seal under you lid(mines didnt) or the spring that holds the cap down is not strong enough
Not sure what you mean here... do you mean that the fuel is going thru the line that connects to your exhaust? does this line have the connection on the top of the filler cap or on the tank itself? If it's on the tank then you should probably try a new tank making sure it has the primer nipple on the top of the cap. Have you any pictures? also it could be that your fuel line is split, check and replace your fuel lines.
