NTC 3 gearing .
NTC 3 gearing .
I want to shorten 1st gear for quicker acceleration and a taller gear for 2nd gear for more top end ,anybody have any recommendations?Will a 6 gear spread on the spur gears be o.k.?Whats the fastest mph i can get out of it?I am running a .12 Novarossi RS 12 S-5 (pretty much the same as a NS12 S-5 minus .05 hp).Thanks for any help.
VA
RE: NTC 3 gearing .
The N/RS12's can handle a 6 tooth spread. You need at least 180ft straight to take advantage of it. I use a 21/54 27/48 on a 200ft track. If you need more lower end, 20/54 26/48. But again, if your straight is less than 180ft, use a 4 tooth spread.
