mt12 stock settings?
RE: mt12 stock settings?
not sure but when my needle settings get all messed up i just set them both at 3 a piece, the engine will start and run plus it's rich enough not to burn up your engine.
i asked serpent and they said:
>A good starting point for the carb. settings are;
>High speed needle + 5 turns out
>Low speed + 2.5 turns out
>Idle gap of .6mm
>Brass spray bar adjustment screw (if installed) flush with back or carb.
>Idle gap of .6mm
