VENOM SPEED METER AND NTC3+
RE: VENOM SPEED METER AND NTC3+
As long as it is side exhaust it will fit. I also believe there is a pipe by rd logics that is made for the rs3, looks the same as the THS pipe.
nice, do you plan on getting new gearing for higher top speed?
What settings did you use in the speed reader? how far does your car move in one revolution of the shaft?
NY
I'm installing my gears after I check how fast the car goes with the cvec pipe. I wanna check the speed after every mod. I have higher gearing and I also purchased a lightweight clutch bell. My car travels 3.2" per revolution. It's not on the drive shaft, it's' on the plastic part at the end of the shaft.
NY
Just tested the car with the pipe (properly tuned) and I got 60. I never thought I would get that much out of it with just a pipe.
