flat pack question
NJ
flat pack question
hey guys i got my flat pack reciever battery pack today and i want to know how long i charge it for i got the 1400ni mh how do i charge it for
Banned
RE: flat pack question
you can safely charge a nimh pack at 2x the capacity which would be 2.8 amps but for a regular rx pack probably overkill to charge that in 30 minutes. I would charge it at 1/10 capacity or 150mah for 10 hours when not in a rush. If you have a peak charger it will stop when the pack is full. If you are in a rush I would set it to 1 amp or so and be gentle on the pack.
I see you are in hillsborough. not far from me. where do you run your cars around here?
NJ
i live by the school school so i run my cars all over the place but i got this battery today and i want to charge it i dont know if i should leave it for the night or i should just sharge it for 30 mins cuse it is the first charge
NJ
i have amdp charger
the one in the link
http://www.hobbieguyrc.com/catalog/o...er_2772868.htm
its the ofna one
the one in the link
its the ofna one
Banned
ok...that one is probably 50-150 mah. I can't read the type. Take 1400 and divide the mah that it says on the charger. That will give you the time to charge.
i.e. If it says 50mah charge rate then it is 1400/50 or 28hours to charge a fully discharged pack. If it is 150mah then it will only take about 10 hours.
