Help with RS4-3 turning problems
Could anyone please help me fix my set up.
I am spinning out every time I turn my RS4-3 when turning in an anti-clockwise direction.
The problem is not present in the opposite direction.
My current set up is foams 38 frt and 40 rear - no limited slip in both fr and rear gearboxes.
There is no binding that I can feel.
Thks
Thks
RE: Help with RS4-3 turning problems
your problem is probaly because you are running softer foams in the front. Run 40 shore in front and run 37 or 35 in the back. Or you can just switch your fronts and your rears.
Later
Later
Try the tire thing because that is what happened to my rs4 and I couldn't figure it out but then i switched the tires and it worked
