RS4 3 EVO Need Help
NY
RS4 3 EVO Need Help
Hi,
I need some help. What would I be needing to replace in my stock RS4 EVO so it can give me better handling at the car park which has uneven surface and lotsa small stone/pebbles... I also notice that this car is prone to breakage at the front upright left or right, the screws that holding the dogbone suspension that connects to the wheels can be easily be remove with a couple of vibration or a couple of runins at the small stones, that is why a couple of runins then I have to stop the car just to check the screws. Do they make a front upright set that is made of metal or stronger material than plastic? also can I make this car higher the bottom of my chassis has too many scratches already and I dont even have this car for a month yet. thanks
RE: RS4 3 EVO Need Help
"uneven surface and lotsa small stone/pebbles..."
Try to find clean even pavement ,stay off that uneven/ pebble infested stuff. And locktite is a R/C's best friend!
