Offical nitro tc3 thread
#501
RE: Offical nitro tc3 thread
one question wich set up should i use? the standar when building the car on manual v2 or in the same manual at the last page says optional foam tire set up or the setting from ae web site barry baker revelation raceway he won 1st place on 03 this is where i use my car at revelation should i start from his set up or the manual.?
#502
Finally got my 2nd tc3, the first I drove once and sold like an idiot, this time, I bought one from a member. Nice aluminum top chassis, full cvd's, carbon parts, nice servo's and it happens to have RB CONCEPT V.12 on there.
I want to say that I have a fusion. The fusion is really the bomb, but I never expected what I seen from this car. The guy put a one way diff in the front, makes a world of difference from stock.
I just need to know how to tune this engine!
Rick
Rick
#503
LA
I need some help I'm setting up my ntc3 for some parking lot drag racing and don't know how to set my car do i need to go + camber or - camber and etc etc etc i will appreciated if y'all give me a hand on this. every time i post something on the onroad forum no one shows up to help me!!
#504
it seems that the ntc3 is dying nobody replies ? but for me i will still hold on to it i will keep it till they come out with something new who knows might happen next year? in the meanwhile ill keep practicing till i get beutter so i can piss lots and lots of v ones rrr and mugens and the rest
#506
TX
savage the setup i use for drag is 2deg toe in rear 0deg caster i think its 6deg camber and 0deg toe on the front and gearing 54 tooth 1st 48 tooth 2nd on the spur and 20 and 27 on the clutch
#511
NY
hey what do u guys think about this engine??
http://cgi.ebay.com/O-S-18-CV-R-P-w-...QQcmdZViewItem
#512
IL
That is a very good motor puts out hella power but it is only going to beat stock cars yet you will beat them by a few feet now if you go against a modded car they will beat you by a few feet but even so it is a very good motor I still have mine even after I bought my t.z. AND IT IS A BEAST. but I drag race and run the same gearing as flynvy5 but there is a mistake in his numbers if he runs that gearing then I am sure he is on the brink of stripping gears your spur difference is suppose to be the same as your pinion difference so in that respect he should have a six tooth diff on the pinion now that could be minus one on the 1rst or second but hey I could be wrong but I always keep them the same.
hope this helps
hope this helps
#513
How about this new motor from AE
http://www2.towerhobbies.com/cgi-bin...?&I=LXPRL0&P=0
#514
IL
by it being new I don't know but I am an avid o.s motor buyer (at least the small blocks) so I dont Know sounds cool tho.
#515
NY
i was thinking about that engine and than sent it to http://tntmods.com to have it work on
#517
CA
zxknight: dont go w/ tnt mods. i just read a review on an engine modded by them and the reviewer said that the stock engine was more powerful.
#518
LA
http://cgi.ebay.com/STS-D3R-12-Nitro...QQcmdZViewItem and its all ready modded!!
ORIGINAL: zxknight
i am also looking for a .12 engine for under $200.
#519
TX
i thought my gearing was a little loose going to play with it i have all the gears so will put it on the "strip" and see what kind of speed i can pull
#520
what r good foam tires that has good grip and r strong and durable i keep breaking the front ones i bought pyre tires something like that.?
#524
tomorrow will be going to practice just got my threaded shocks 3 shoe fly wheel ,vented clutch , new stock chasis lets see how the 3 shoe works
#525
ORIGINAL: raptorddd
